Supraforums.com
Go Back   Supraforums.com > Supra Specific > Shops & Part Reviews
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 08-27-2008, 11:48 PM   #1
MIX
Sound Awake
MIX's Avatar
HeadGames™ Cylinder Heads
How are HeadGames™ 2JZ-GTE heads for quality and workmanship? I was refered to HeadGames but I don't know what they offer. I was hoping there are a few Supra owners out there who have gone the HeadGames™ route and could share your thoughts and opinions about what they offer. Maybe how they compare to the competition...
Thanks!
MIX
__________________
> 1995 Toyota Supra Turbo > 6-speed > 33000 miles
> 1996 Lexus SC300 - FOR SALE 08/20/2010 - PM Me for details!!
MIX is online now   Reply With Quote
Old 08-28-2008, 07:11 PM   #2
ohioko4s4
SupraForums Member
ohioko4s4's Avatar
Quote:
Thanks!
MIX
I don't believe Dave has an equal in the Supra world. He has built 3 heads for me, each one has been perfect. We have always made leading power relative to what others have at similar boost. I have never hard of anyone being disappointing with the quality of his porting and parts used.
ohioko4s4 is offline   Reply With Quote
Old 09-02-2008, 11:17 PM   #3
MIX
Sound Awake
MIX's Avatar
Quote:
How does Dave's cost compare to the cost of Titan heads?
MIX
__________________
Old 09-04-2008, 08:33 PM   #4
Suprasarecool
6 speed
Suprasarecool's Avatar
I believe Titan heads are now CNC ported. The price has remained the same if not gone up. Don't understand why it's not cheaper now since the porting is automated...
heard nothing but good things about Headgames and Titan heads though..
someone NEEDS to come up with an aftermarket casting. stupid shitty ass flowing 2JZ heads...
__________________
94 Supra TT blk/blk 6spd
big single, cams, and fuel in progress...
00 Camaro SS blk/blk M6
cammed, headed, and sprayed LS1, moser 9"
01 Camaro SS blk/blk M6
87 BMW 325ix - 24 hours of LeMons racecar!!
Suprasarecool is offline   Reply With Quote
Old 09-04-2008, 09:31 PM   #5
Smokey1226
Hawtness
Smokey1226's Avatar
+1 to that! So many ballers on SF why not all chip in?!?!
Smokey1226 is offline   Reply With Quote
Old 09-04-2008, 09:54 PM   #6
X2daC
Kirisute Gomen
X2daC's Avatar
Why? An aftermarket casting would do no good, they would spend more money on R & D than they would actually make.
Not to mention we make up a small portion of the automotive community. Our motors are not as common as the SBC, BBC, or SBF crowd.
Why don't you think for a second?
A better flowing head would max out your boost sooner, with a bit of a "shitty" flowing head as you say, it would allow you to run more boost.
So take your pick, more boost with decent flow, or less boost with maximum flow.
__________________
X2daC is offline   Reply With Quote
Old 09-05-2008, 04:22 AM   #7
Suprasarecool
6 speed
when you're running a T6 framed turbo, im not worried about maxing out the turbo..
the 2JZ head does not flow really well. you need to look at what some of the other stock production heads are flowing from the factory.. 350z? shit even the honda b series heads
I should probably just leave my head stock so i can boost more and make more power that way then huh? I'll choose making more power on a more efficient set-up (in this case, the cylinder head) over making more power with more boost any day.
my antiquated ass V8 with a single intake valve, ported stock LS head flows 282@.400 lift. they were $1200 brand new for the pair, no core needed.
Since we have no after market alternative...I will be taking my Supra head to HeadGames or Titan..
__________________
Old 09-05-2008, 10:43 AM   #8
X2daC
Kirisute Gomen
X2daC's Avatar
I'm just speaking from the other side of the fence.
I've heard the 2JZ flowing around 250 to as much as 270.
I like how you're comparing a head on a naturally aspirated motor where flow through it matters most to a head on a turbo motor.
Old 09-06-2008, 04:35 PM   #9
rjsmd
SupraForums Member
Everyone probably has his or her favorite, and the reality is there are more than a handful of tuners capable of improving the flow performance of the 2jz head to withing a percent or two of each other. Given the specific shop cited, however, few would argue that their capabilities and track record are deserving of being on anyone's short list when considering head work.
rjsmd is offline   Reply With Quote
Old 09-06-2008, 05:07 PM   #10
Spoolin Turbo
Spoolin Turbo's Avatar
Headgames has done many heads but a bit pricey. Im sure they do good work though.
I had Portworx do mine and I love it. I wanted a streetable car nothing crazy so I didnt really want high port numbers.
They got the highest ive seen on a GTE exhaust side where it matters around
They are doing (6) other GTE heads up for some Canadians.
Spoolin Turbo is offline   Reply With Quote
Old 09-07-2008, 04:19 PM   #11
HEADGAMES
SupraForums Member
Thank you Mr."Hollywood"Carter!!
MIX
We are right in line with everyone's pricing...but we do everything in house.
And...as far as a aftermarket casting. It is first off, a absolutely huge investment with minimal return for your money and performance. Your talking about a factory head we can port to make 1800+hp. Besides, it would require different cams, belts, and gears since one of the few things you could do would be to change valve angle. There really is no sense in it. The factory head can flow almost 320cfm when ported correctly. And that is a head none of you would ever want to run in anything under 1500whp.
There is ALOT more you can do with V8 heads then these.
HEADGAMES is offline   Reply With Quote
Old 09-07-2008, 08:47 PM   #12
Ed_Alpha-Racing
Alpha Racing
Everytime I run into Dave he's got some sexy chick with him
Ed_Alpha-Racing is offline   Reply With Quote
Old 09-09-2008, 02:23 AM   #13
jt granberry
WI-FI FTW, GTFO fuse box!
jt granberry's Avatar
Jaime, Don doesn't do any of your head machining/work?
__________________
www.indemotorsports.com
STOCK CAMS! WOTM 67 DBB kit, 6MT, fully built block, +1mm Ferrea, 5 angle V.J., ported head, Greddy 4 row, AEM, TRD diff, fully shaved, wire tuck etc. AC, PS a 100% street car.
RT=.020 Cash purse winner 7th annual midnight run/after9 events @ Speedworld
60 footer=1.46 since my 1.04 didn't count. :(
MPH=138.7
ET=10.61
jt granberry is online now   Reply With Quote
Old 09-09-2008, 07:44 AM   #14
DefconAdmin
SupraForums Member
DefconAdmin's Avatar
No portdaddy Localio does them!
Quote:
__________________
93.5 Supra
2004.5 Ram 3500
DefconAdmin is offline   Reply With Quote
Old 09-09-2008, 08:32 AM   #15
Sound Performance
SPRacingOnline.com
Sound Performance's Avatar
Location: Well, Dick, here's the deal: I'm the best there is, plain and simple. I mean, I wake up in the morning and I piss excellence. You know, nobody can hang with my stuff.
Dave built the heads for our 350z that just reached 1017 RWHP. The amazing thing is that the car engine makes HP up to 8500 which is unheard of for the VQ motor!! I can probably rev it higher too!! Here is the dyno graph:
__________________
XXSUPRAXX@AOL.COM Cell# 630-205-6690
Do Not PM Me!! IM me @ XXSUPRAXX
Sound Performance is offline   Reply With Quote
Old 09-09-2008, 09:18 AM   #16
FYRARMS
Super Moderator
Troll Slayer
FYRARMS's Avatar
My friend and I sent a set of frickin' Ferrari 456 V12 heads to Headgames for some mild work. Considering they were damned Ferrari heads, Dave beat anyone's pricing on labor and parts. Turnaround was quick as well.
Got Ferrea in yo' Ferrari? We do. Thanks, Dave!
--- Eurotoys, Ltd.
FYRARMS is offline   Reply With Quote
Old 09-10-2008, 12:10 PM   #17
Boost Junkie
SupraForums Member
Quote:
Nice! What transmission are you using to hold that power? The stock 350 6-speed won't hold anything like that kind of power, will it?
Boost Junkie is offline   Reply With Quote
Old 09-10-2008, 11:09 PM   #18
Sound Performance
SPRacingOnline.com
Quote:
The gears in the 350 are plenty strong!! Now the syncros..... that's a diff story along with the diff and axles!
__________________
Old 09-10-2008, 11:21 PM   #19
Krister
Holset powered
Krister's Avatar
--- Eurotoys, Ltd.
Nice to see someone tuning a Ferrari. Any before / after results or pics of the ports?
Krister is offline   Reply With Quote
Old 09-12-2008, 11:42 AM   #20
FYRARMS
Super Moderator
Troll Slayer
FYRARMS's Avatar
Krister, I'll see if I saved any.
Old 09-12-2008, 01:35 PM   #21
sickazzevo
SupraForums Member
I know from the evo world headgames does MOST big shops heads. they pretty much have their name on the highest hp heads in the evo world
sickazzevo is offline   Reply With Quote
Old 09-12-2008, 05:00 PM   #22
HEADGAMES
SupraForums Member
Ferrari 456 valve guides are notorious for going bad, I think the car in question had 12k on it and were worn to the point it hurt the valve. We made custom valve guides out of manganese bronze and custom Ferrea valves to cure the issue..but here is some pics, some are not so clear.
Combustion chambers
exhaust port
Intake port
Old 09-12-2008, 05:01 PM   #23
HEADGAMES
SupraForums Member
I didn't even know you were with them!
Old 09-13-2008, 05:18 PM   #24
FYRARMS
Super Moderator
Troll Slayer
FYRARMS's Avatar
Quote:
Well, I am not employed there. I am just in the shop all the time. Mike at Eurotoys is my best friend and the only guy that touches my cars. The guy is a phenomenal technician. We've got a spare GTE head for my Supra coming your way soon. And I want the Larry Prebis price, damn it.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
cylinder heads Daugherty_3 MKIII Technical 2 11-26-2006 08:25 PM
Do the 2JZGE Cylinder Heads bolt up to the 2JZGTE Block? Sins4u33 MKIV (1993-1998) 26 09-08-2005 07:56 AM
Cylinder heads ZEE MKIV (1993-1998) 1 09-01-2003 06:25 PM
Any one have flow data for stock 7M cylinder heads? TwoLaneBlackTop MKIII Technical 2 02-23-2003 08:08 AM
Powered by: Mvp Motorsports
Credit Card Processing
