Supraforums.com
Go Back   Supraforums.com > Supra Specific > Road Racing & Autocross
Register FAQ Members List Calendar Mark Forums Read
Reply
Thread Tools Display Modes
Old 01-11-2008, 02:39 PM   #101
gixxer_drew
Supra + DSM = heaven
gixxer_drew's Avatar
If you don't mind me asking, what kind of brake setup are you making?
gixxer_drew is offline   Reply With Quote
Old 01-14-2008, 10:59 PM   #102
Shitzu
Former 1.5jz-Powered MKIV
Shitzu's Avatar
great info guys......I am so tempted to doing this mod since I have a set of bilsteins on the way, but it sounds like if I wanted to retain the 1 finger gap all around, I would have to go with a higher spring rate and get the shocks revalved.....would that be neccessary or can I just go with Drew's setup?
__________________
Jun. 93-Jun. 04, Stock 2jzge 5spd(W58)===>Jun. 04- Oct. 07, complete 1jzgte swap w/Soarer R154, 435wrhp;370ft/lb tq @20lbs untuned===> Nov. 07 to Aug. 09, 1.5jzgte Swap w/Aristo 2jzgte short block, ???wrhp;???ft/lb tq @ 20lbs untuned===>Sep. 09-Present, Full jdm 2jzgte swap w/USDM Cams & Injectors......Probably the only MKIV that had all 4 different jz configurations.....
Shitzu is offline   Reply With Quote
Old 01-15-2008, 08:02 AM   #103
gixxer_drew
Quote:
Finger gap measurements depend on a lot of factors. The reason for the height requirement is the length of hte bilstein bodies. If you had an issue with my setup you would have an issue with any other setup using those bilsteins unless you oversprung them. I left a certain safety margin with the heights, you can certainly try it just make sure to measure your travel wth the zip tie and keep at least a half inch of the factory bump stop in case you do bottom out.
__________________
ANDREW M BRILLIANT
Aerodynamicist/Data Engineer
http://www.amb-aero.com/
Old 01-15-2008, 01:44 PM   #104
Shitzu
Shitzu's Avatar
I see, thanks Drew....
__________________
Old 01-18-2008, 11:29 AM   #105
1jzmkIIIproject
SupraForums Member
Will this Bilstein setup and spring rate work on the mkIII's too??
1jzmkIIIproject is offline   Reply With Quote
Old 01-18-2008, 11:34 AM   #106
gixxer_drew
Most likely not
Old 01-31-2008, 09:45 PM   #107
cyberdiamond
V8 VVTi, 6 Speed Swap!
cyberdiamond's Avatar
Does anyone know the stroke length of these shocks?
cyberdiamond is offline   Reply With Quote
Old 01-31-2008, 10:18 PM   #108
gixxer_drew
You know, I never measured that. Please post up if you get a chance to find out. The next set i get my hands on I'll measure as well.
Old 02-01-2008, 12:31 AM   #109
Wiisass
SupraForums Member
Wiisass's Avatar
Quote:
Yes it will. Didn't you send me a PM on Supramania. Or was it someone else?
Either way, Bilsteins with a spring sleeve and 2.5" coilover spring will work on an Mk3. I don't know if those rates are the best though. And that really depends on a lot of things. But it can be done, I'm trying to get accurate dyno plots of the stock Mk3 and Mk4 bilstein dampers so I can figure out what springs will work best with the dampers and balance the chassis properly. I do have some data for the Mk3 Bilsteins though, but it's just a picture of a printout.
Tim
__________________
Theory In Practice
Clubloose
Wiisass is offline   Reply With Quote
Old 02-07-2008, 01:10 PM   #110
SCV8
SupraForums Member
That's what I thought would be the case with the Bilstein replacements(slightly lower ride height w/stock springs), but the car sits very nice now with the added circlip groove. If I had the threaded sleeves it wouldn't be as much of an issue.
The parts, as provided, would have made for a funky install, and I have done this before!
SCV8 is offline   Reply With Quote
Old 02-08-2008, 11:48 AM   #111
evileagle
SupraForums Member
Wow, excellent info. Just went through both threads. I think its a great idea especially as a cost effective solution including great performance and streetability. Only problem is, im stuck between this setup and a particular coilover setup. How do you think these will compare to a set of JIC FLT-FAS's? Those go for around 1350 shipped and im stuck between this idea and them. I dont ming shelling out the extra money, but i do live in LA and this is a daily driven SC300. Its a real tough choice for me, what do you think gixxer? Any info greatly appreciated.
evileagle is offline   Reply With Quote
Old 02-08-2008, 12:10 PM   #112
gixxer_drew
Thanks for the compliments!
One of the primary reasons I developed this setup is that I was dissatisfied with the off the shelf options, specifically including the JIC.
Honestly for a daily driven SC300: bilsteins + stock supra springs, front springs on the lower perch + TT rear sway bar = magic and thats for all of like $600. Thats an option on a very low budget that will perform extremely well for street.
Old 02-09-2008, 11:54 AM   #113
SCV8
SupraForums Member
I concur...
Bilstein offers a lifetime guarantee on their street replacement parts, try to buy that in an aftermarket performance shock of that level for even twice the price, and I doubt you'll find anything.
I use these in the front coils to help balance the car with the stock TT springs on my SC;
http://www.speedwaymotors.com/p/689,...g-Spacers.html
Old 02-09-2008, 05:16 PM   #114
thedarcsage
SupraForums Member
thedarcsage's Avatar
wow, so i put the stock bump stop back on and when i lower the car back down to the ground, the bump stop is sitting on top of the shock body
did i do something wrong?
when the car is up, there is a 2.5" gap from the bump stop to the shock body
i have 2-3" left to lower on the coilover sleeve
when it is lowered back down to the ground, the gap is 0 lol
Edit: ok cool, just talked to drew and the bump stop is way too long
i need to trim it down to about 1/2"
alright, thanks!
thedarcsage is offline   Reply With Quote
Old 02-09-2008, 05:52 PM   #115
mark94tt
Oh Snaps
mark94tt's Avatar
Are those pictures post cutting the bump stops?
mark94tt is offline   Reply With Quote
Old 02-09-2008, 05:57 PM   #116
thedarcsage
SupraForums Member
those are factory bump stops before cutting -- uncut
i raised it to the top of the sleeve and now there's a 1" gap, so cutting the bump stop should do it
Edit: maybe i have to increase the stiffness of the rebound adjustment to 50% or more for the stiffer spring rates?
my other thread with questions about the koni rebound adjustment...
http://www.supraforums.com/forum/sho...d.php?t=476388
Old 02-09-2008, 08:31 PM   #117
gixxer_drew
Yah what happens is the stock bumpstops are meant to fit inside of the stock upperhat where the new upper spring perch sits so if you don't cut them they are WAYYYY too long. Stock bump stops are like 3"
Old 02-09-2008, 09:41 PM   #118
mark94tt
Oh Snaps
mark94tt's Avatar
Drew,
In this setup have you made the bumpstop a part of the suspension or are you just using the bumpstops as a safety device for the shocks? The guy at Shock-shop.com recommended going as short as possible on the bumpstops and getting stiffer springs so we can retain our travel.
Old 02-09-2008, 11:11 PM   #119
mteele
SupraForums Member
Drew, what do you mean by front springs on the lower perch? Sorry if thats a dumb question....I just bought my new SC yesterday, so I havent really looked at suspensions in about 3 years
mteele is offline   Reply With Quote
Old 02-10-2008, 11:07 AM   #120
gixxer_drew
Oh yah, let me explain the bilsteins off the shelf are setup to use stock style springs, they have two positions you can put the spring perch, stock height and 1/2" lowered. Put the fronts only on 1/2" lowered and leave the rear on stock height. That little bit of rake makes the car oversteer more.
Mark: I agree with shock-shop and Chris over there is a great guy. You need to have your spring rates proper and little to no bump stop I only run a very very small bump stop to cover me in extreme circustances. I prefer to know when I need more travel or stiffer springs.
Old 02-10-2008, 02:04 PM   #121
mteele
SupraForums Member
Drew,
Thanks for the help! I guess I have to decide on stock Supra springs or trying this setup you've devised I'll definately either go for your "street" setup or the TT springs....money is not an issue, its just about what I'm comfortable with. I had originally been planning on a Tein CS setup but I think I may give this a shot first. The whole thing with the bump stops is still a little unclear to me, I should probably re-read it all now that its not 3:00am.
I got some TT sways & subframe mounts on the way. Is the front sway bar the same on the cars? I remember on my old SC300 I had the rear one swapped but I cant remember what the deal was on the front.
I feel like a newb all over again haha
Old 02-11-2008, 08:45 AM   #122
gixxer_drew
Yes, that information on bump stops is contained above. hiken posted the part #s for some aftermarket bushings that fit the bill or you can attempt to cut your stock ones if you prefer.
Old 02-11-2008, 05:49 PM   #123
thedarcsage
SupraForums Member
it has been too long driving on stock suspension for so many years
and pictures don't do justice to how they look in person
so far so good!
still gotta cut the stock bump stops some more as i only cut off an inch on one side
next is to test them
Old 02-11-2008, 06:26 PM   #124
Pedro TT
b00bies!!!
Pedro TT's Avatar
That suspension looks amazing.
Pedro TT is offline   Reply With Quote
Old 02-11-2008, 07:31 PM   #125
mark94tt
Oh Snaps
mark94tt's Avatar
Did you ever get those pictures as hiken described in his post:
http://supraforums.com/forum/showpos...9&postcount=45
It would be nice to add that to the how-to on the first page.
Also are those bumpstops the same for all four corners?
__________________
94 Supra TT 6spd
06 STI
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by: Mvp Motorsports
Credit Card Processing
