#1 |
SupraForums Member
1JZ Swap into an '87 Supra n/a
The front clip...
![]() ![]() ![]() ![]() ![]() ![]() Pulling the engine... ![]() ![]() My in-house bling master Dan polishing the manifold... ![]() Timing belt, water pump, seals and gaskets, and clutch being replaced... ![]() ![]() ![]() ![]() ![]()
#2 |
SupraForums Member
![]() ![]() ![]() ![]() ![]() Wiring! ![]() ![]() Engine with polished parts installed... ![]() Engine pretty much ready to go in, harness, vacuum lines, etc all installed: ![]() ![]() ![]() ![]() Installing the '89+ crossmember... ![]() My signature "Dr Tweak Pose".... ![]() Installing the engine...
#3 |
SupraForums Member
![]() ![]() Bolted in! ![]() ![]() Engine just about ready to go here. A few minutes later it fired up on the first try... as always ![]() ![]() ![]() Swapping out the tach... ![]() Changing the pump requires dropping the tank... loads of fun!!! ![]() I've just got a few finished pics left to upload. |
#4 |
Jihad Killer
Awsome bro. very very nice, looks like you know what your doing!
Ax |
#5 |
SupraForums Member
Why thank you. Yes I've been doing engine swaps in Toyotas for a long time.
#7 |
SupraForums Member
HEHEH
I'll post up some more pics this coming week of the custom stainless mandrel-bent exhaust I'm building for it. -Doc |
#8 |
single 1j
nice... it reminds me of when i did my swap.. all i gotta say is enjoy extending the wire harness if you decide to do it yourself..
__________________
90 na w/ a single 1j |
#9 |
I'm a sleeper ...
#10 | |
SupraForums Member
Quote:
Hi Andy! I can't wait to take you for a ride in it!
__________________
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
http://www.phoenixtuning.com/ |
#11 |
Stock is boring :(
your stock intercooler piping fit with the 7m fan shroud and aux fans? nice!
#12 |
SupraForums Member
No, I had to customize the piping on the passenger side. Thankfully I had some black intercooler piping that was just the right size!
#13 |
SupraForums Member
Hey this might sound stupid, but is there a vicous fan attached to the motor that fits the 7m fan shroud. what is it attached to etc... As i was going to go electric fans but if i can get a fan that fits the fan shroud i will do this. My 1j is from a jzx81
Cheers |
#14 |
SupraForums Member
Yes, that's the 2JZGTE water pump and fan setup. There's a list of what you need here: http://www.1jz-gte.us/92Supra8.html
-Doc |
#15 |
SupraForums Member
Looking good man. How long did it take you to get it running once you put the motor in the car? I'm currently trying a 1jz swap. My garrett gt35r is suppose to arrive tomorrow. I've got a thread started on SM, but not here. I'm kind of scared about installing the motor, but I've come too far to turn around now. Hopefully I can handle it. Your's looks awesome.
#16 |
SupraForums Member
It took me around 4-6 hours, but I do this fulltime. Take your time and you'll be fine. If you need a hand with the wiring, just let me know, I specialize in converting Toyota wiring harnesses.
![]() -Doc |
#17 |
Ladies like the PSS..I
#18 |
SupraForums Member
Thanks!
Here are the pics of the 3" mandrel-bent stainless exhaust I put together, side by side with what was on there... ![]() I suspect this will flow much better! ![]() ![]() ![]() ![]() ![]() ![]()
#19 |
computer illiterate
Wow it all loooks great. I'm also doing a 1j in an 87 na. Was wondering if you had time to help me with a couple of questions? I'll pm ya.
#20 |
Project:: Reaper
GYOD!!!!! thats an INSANELY clean install
that polishing looks amazing |
#21 |
SupraForums Member
How long did it take you for the install? It looks like you guys really moved through every process with no difficulties, very nice.
#22 |
SupraForums Member
Well I really took my time, I think that it was around 5 or 6 days of work including building the exhaust, something like that. Total downtime was longer since we spent a little time waiting on parts like the exhaust, which wasn't originally planned.
![]() -Doc |
#23 |
SupraForums Member
Hello i Have a Supra, the 7m-ge non turbo, and i want to do the swap for the 1jz, my question is, the transmition that i have works for that engine??? my transmition is manual.
and where is the best place to buy a engine, beside Ebay.? |
#24 |
Jihad Killer
ebay is the only place!!
#25 |
Project:: Reaper
you need a R154 not the W58 you have now
you can go to Jarco, JHOT, Driftmotion theres lots of places i personally prefer JHOT |
| Thread Tools | |
| Display Modes | |
