#1 |
NSW supra club Member
DIY: Turbo Heat Shield, write up, with pics.
How to make a turbo Heat shield.
By Danny/MAZMAN ---------------------------------- Ok, here is a very good do it yourself heat shield that anyone could do, and the end result is fantastic, just as good as the real deal if not better, as there is no welding on it, and wont cost you an arm and a leg. Go to the usuall shops like k/mart, big-w, target ect... where you will need to find a large bowl, made of stainless steal. I used a stainless steal bowl of 0.3mm, already polished. its thick enough to not flex/vibrate/bend, but thin enough to cut easy. Look for the design you would like and the shape of it, its up to you to find a look that you will like, i bought a plain and simple design, with straight walls, no bends or funny shape design. You can get aluminium ones, coppers ect... but i think stainless does a better job and ends up looking the best. You will also need to measure your rear exhaust housing diameter, so as to not get a too small one or too large. My turbo is 210mm o/d and the bowl i bought is 220mm, so i have a gap of 10mm between my housing and my shield. ![]() ![]() ------------------------------------------------------------------------------ Once you have decided on your bowl, you will need to make a template. I just used a thick cardboard to make my shape. Bend it to the shape you want, and sticky tape the other side on, so as to have the nice bendy/oval shape(see picture). Put it on your housing and try to get the best possible bend and the look that you want. Remember to get the width that you desire as well, and the lenght. On my turbo (gt42) i had small threaded holes on the rear part of the housing, so i shaped the cardboard and made the holes that you see behind it. This is where i will be bolting up the shield to the housing. I understand that every turbo is different, but if you have these holes at the rear of the housing, you can measure them yourself and drill the holes to match your housing. ![]() ![]() ---------------------------------------------------------------------------- Now that you have a template to make your shield from, its time to cut the bowl to suit. So measure up your template, put it against the bowl and make the required markings where you will cut it off. You will be cutting of the head of the bowl(the top part where the handle is), and leaving the bottom part of it so you have something to bolt up to. I used a cutting wheel on a grinder, taped up the bowl section with masking tape on the part i will use, so not to scratch/damage it, and cut my shape. ![]() ----------------------------------------------------------------------------- Once cut,i used a fine file to get rid of the sharp ends, and then used a fine sanding wheel to get a smooth finish. I cut the lip at the front of it just a bit, to make it look more professional. Now all that you are left with is to put to template against the shield and mark the holes where you will drill, remember, put the template on the inner side of the shield when marking(not on the outer side), this will make sure you dont stuff up your measurements. Once you have drilled the holes, again, sand down the sharp edges that the drill leaves (tip: drill from the outside of the shield as this leaves edges on the inner shield where you dont see it). ![]() ![]() ---------------------------------------------------------------------------- Now to find the correct bolt size and thread that will match your housing thread and bolt it on, and your done!!! Then enjoy the mighty fine look it will give you as well as helping all that heat under your bonnet. On the australian/RHD, our brake master and clutch master is very close, it helps greatly with this shield. I couldnt be more happier with the end result. I paid AU$26 for the bowl, and did the labour myself, so that cost me nothing, In the shops, they are asking AU$250 for this piece. I have higher resolution pictures, but due to size, i needed to be fair to everyone and made them smaller. ![]() ![]() ![]() ![]() -------------------------------------------------------------------------------------- FINAL RESULT ![]() ![]() ![]() Hope ive gave someone an idea and a reason to make one, even if you do stuff it up, remember, you will still have another piece from the half of the bowl that is left over. (you can make 2 pieces from one bowl). Enjoy, Danny P.S. i dont know how long this post will last, due to my webspace limit, so if any1 wants to host it, they can, otherwise just see how long it will last till. Last edited by MAZMAN; 12-22-2005 at 04:58 AM. |
#2 |
SupraForums Member
The first pic I saw looks ghetto. But the end product looks very nice. LoL Thanks for the write up.
#3 |
SupraForums Member
lol not to shabby
#4 |
SupraForums Member
Hahaha, has to be the funniest mod that is actually pretty cool.
#5 |
SupraForums Member
great DIY you got there danny.
looks damn impressive indeed. great touch up to the engine bay that is aesthetically advantageous as it is efficient. 10/10 write-up.
#6 |
SupraForums Member
Funniest write up ever. The way took the pic of the retarded looking bowl. LOL
#7 |
SupraForums Member
Brilliant
Fantastic idea ... I love to see these types of DIY threads.
+1 for a great write-up!
__________________
Pete |
#8 |
6Spd TT Aerotop
Haha, concept sounds so ghetto, but at the end it's the best idea around.
Dan. |
#9 |
SupraForums Member
That is a great idea Danny, cheap and effective, and also looks good
Good write up to
#10 |
Posts: n/a
wow you belong in a guiness beer commercial. i kind of prefer actual blankets but that works out pretty sick.
#11 | |
Always on pump gas...
Quote:
BRILLIANT!
#12 |
SupraForums Member
Great idea.. Good job and it looks very professional... Thanks for sharing!
#13 |
Bullseye Dealer
+1
#14 |
That was really cool...nice write up!
__________________
Steve Theodore 2001 Porsche 911 Turbo 1993.5 Toyota Supra TT hardtop - 3420 pounds - SOLD 2003 Lexus IS300 5 speed (with LSD) 2008 Toyota 4Runner Sport Edition Click here to visit the Supra Hardtop Turbo Registry Click here to find out more about professional networking within the Supra world |
#15 |
SupraForums Member
I have a feeling there are going to be a lot of pissed of mothers and wives out there in the near future.
Nice write-up. |
#16 |
ur moms favourite
ah man! sounds great but i dont see nuttin!!!
Any chance of fixing the pics man? |
#17 |
6Spd TT Aerotop
Still working here, they haven't gone down yet.
Dan. |
#18 |
SupraForums Member
Thats awesome, now how to steal my wifes cooking pot, with out her knowing.
#19 |
SupraForums Member
Ill be pot shopping this weekend
#20 | |
ur moms favourite
Quote:
Is your computer maybe displaying it from the cache? |
#21 | |
2jz powered
Quote:
#22 | |
ftmfw.net
Quote:
#23 | |
6Spd TT Aerotop
Re-hosted pics on Elit3.com from my cache.
Dan. Quote:
#24 |
very nice wright up !
#25 |
Newbie
This deserves to be in the FAQs question or somewhere useful.
| Thread Tools | |
| Display Modes | |
